I’m actually in the process of ordering some kenda 909 200x50 now. I want to see what they’ll look like stretched on the hellcat wide
I’d love to see a 150x75.
Someone say 3in 150mm’s? Have my wallet…
Late to the party. I’m hands up for some hellcat wides though.
They are much stiffer/sturdier than any 200x50 tire I’ve seen. Probably helps sidewall stiffness even more if you match an appropriately wide hub to it.
2 of these
4 of these
I cut off one of the legs on the gopro mounts. They both have 3
Awesome, thank you very much for that.
there’s also these if they interest you:
Ive looked at that, nice model. Im just looking for something a little more solid and the mounts that it comes with are pretty bad.
Damn those look hefty
These are so hard to put on. I was able to fit the fronts but now I’m doing the rear and it won’t go past the lip
Tight fit is the best when you get a flat. Just put it on. It will move to the edges when you pump air in.
Can you measure the diameter of hub? These 200x75 and most of the other common esk8 tires fit a ~95mm hub. The more widely used standard is 4in though, or 100mm.
Ok I did get them in with a little bit of grease, tight AFFF tho. @PrinceRein how did you fasten the screws in all the way? The nut doesn’t lock into place and there is not enough room to secure it in place with a socket. What gives?
I was able to do all but one tire. One tire just is not made in a perfect circle. To fasten them the screw goes in the other way. The nuts are only for the rear
Huh, I don’t get it how do you fasten them without a nut…
