Truck, GPS, and CNC foot stop…
Originally I was ordered a set TKP with an adjustable plate… but they messed up my order, sent these things to someone else and they out of stock the color I want to…so asked them to send a set rkp instead of that.
Here the battery part… I’m using copper straps to solder battery… i did three layer per group, each layer can hold 20A with no temperature increase, 30A with 10 degree.
Tip for soldering battary,pre-solder battary and copper straps.
This board is a beast, don’t get me wrong, but it’s not really 13.2kW when the battery is only capable of delivering around 6kW.
You can’t just stick loads of motors on a board and expect huge power, you need the complete power system to back it up if you want to unlock it’s true potential.
Well, until it reaches half speed, its torque will be about twice that of a comparable 6kW 2WD build. But yes, technically you are correct. I wish we had a better way of representing stand-still torque.
@Ean.esk8 This thing is a beast! I can’t believe you wanted to go with TKP at first, and then even with RKP added a steering dampener
I speak about them yes and they shouldn’t use more space on the axle them the etoxx hubs as they are as well offset hubs. No need to use them with big tires thou
