13200W AWD low ride build!
That makes sense then :sweat_smile:
Was reading too fast :see_no_evil::joy:
The e-toxx are offset in a way than they use only 25mm on the axle, the superstars (and phatladz) are 37mm so 12mm more
The only other hubs that i know of which are comparable to the etoxx are the yet non realeased from @Bavioze than i’m craving for ahahah
34mm, 9mm more to be precise… Big wheels need some bearing distance for stability and round spinning.
Yes, sorry, 37 are the TB hubs
Would the phatladz work well with a 200x75 tire like what Ernesto/Kaly uses on his hellcats?
Work with 6.5" to 10"
Here with 6.5":
Here with 9":
I’m loving the rear damper. Worked great when I had mind installed, and the adjustability anywhere from basically non-existent to absurd levels of added stability was lovely. How are you liking yours?
And my God… This build as a whole blows my mind… I think I’ve got a new endgame to aspire to one day thanks for that! :grin::grin::grin::nerd_face:
Love your Baord! Keep going!
Cant you move the damper 90 degrees on the trucks? Maybe that way its not in the way of your foot :slight_smile:
Do like the build , very nice job.
so, here my Charger, external BMS and 0-100v/0-30A super charger which base on Huawei power adpator.
Testing charging, 19.5A
I see what u mean, mate… that’s why i have extend high discharge lipo packs.
My originally plan just build a RWD, lol.
Will swap to some high discharge lipo soon. :relaxed:
haha…thanks, mate… my originally plan just build a simple rwd with TKP, since they messed up my orders and saw too many AWD build…I’m kind jealous. :joy: so decided to go for AWD.
The damper slightly too long will get in touch to the wheel if 90 degress and i don’t wanna cut it…so…haha
Thanks, man…the rear damper really helps a lot…it does reduce the wobbles if through the rough ground. :slight_smile:
The board having some lose connect issues…i thought it is remote issue…so brought a Hoyt puck instead of that…but still happening…
Until I found out the PPM wise start came out, no more issue after replaced the wires. :grimacing:
One of my unity fucked up…seem like motor wires shorted out…(carbon fiber enclosure made it)
It bit weird cause it keeps jumping red light… but no faults been reported on vesc, even on the terminal tho.
I still can read the motor configures, but can’t let them move…
only can turn the faults ESC on through CAN bus, the power switch is fine…just can not turn that shit on. :expressionless:
link to this please?
Here the extend battery part…
using 4mm/3mm abs plastic plate…and some m4 aluminum brackets.
4* tattu 6s 10000mah 25c
builded in some insert threads on the Rayne deck…
made those lipo pack universal to my Trampa as well(coming soon).
Here the link…but it is a custom-made product, no warranty especially not in China. Also risky tho…charge quality depends on the skill that the person has. :slightly_smiling_face:
https://market.m.taobao.com/app/idleFish-F2e/widle-taobao-rax/page-detail?wh_weex=true&wx_navbar_transparent=true&id=611537072870&ut_sk=1.Xf5hMuLiZoUDAMxa%2FN4EN9TB_21407387_1602748405749.Copy.detail.611537072870.3449301579&forceFlush=1
ā€œHUAWEI 4850 G2 can be adjusted to 30-100V 0-30A 30-120V 0-25A, stable without blowing up!ā€
they seem to know what not to do!
