12s8p top box enclosure
Hi everyone!
I’m in the process of building a new board. ATB setup with top box battery enclosure. Just wondering what people are using to house their components? Battery will be a 12s8p 18650.
Pictures, links etc all appreciated. It’s the last thing I need for me build and want it to be rather clean!
Thanks for the help everyone
I’ve seen others using pelican case for top mount enclosure.
I used this for mine :
My 10S4P have plenty of room, i could put two in there, i think a 12s8p can easily fit. The 2000 model is same width and lenght but taller.
Pelican boxes do the job pretty well
I use pelican cases for photography and I personally think its a little too clumpy? I really like the trampa box but at £275 it’s a little expensive.
I’d be interested to see if anyone has used a regular enc just mounted upside down , I have a similar question, I can’t bring myself to use pelican style on a thane board
I use this, not cheap but its pretty good looking and nice quality.
I use this for my trampa build. Holds a 12s2p 10ah lipo setup.
https://www.jaycar.com.au/sealed-abs-enclosure-240-x-160-x-90mm/p/HB6134
Pelican cases would be the better option though
From a distance that looks awesome. Do you have any closer pictures? Also what battery set up do you have?
Yea it would look shit and really disproportionate haha
I use a 12s6p but my vescs are in there aswell. You can check my build thread or my instagram (check the stories there you can see how I modified it)
https://www.instagram.com/creavenger/
12s9p 20650 cells in a diy junction box
PVC junction boxes +1 12s10p
This black one is going to fit perfectly in the black hole :smiling_imp:
This is what I used from amazon. It’s a little over sized so 9P may have fit but it would have been a bit tighter than I really wanted.
12S smart BMS on the front of it. So you could also probably put a 13th row of cells in there if you moved the BMS ontop but I wanted to keep more room above incase I decided to put the ESC or other items in the lid.
Dude! What deck is that?! Loooks soooo niiicccee!!! Also sick skinz. Is this a @Sender job? Can’t wait to see this built.
Building an emtb myself atm, went bottom enclosure because I can’t bring myself to top mount lol (go with what you know). Been watching mtb builds closely lately.
Custom made 3D printed + laser cut stainless steel
Thanks man! It’s an MBS Pro 97 deck
It had some cosmetic damage on the nose but needed cut anyway so I sent it to Mike and Tim to work their magic. Certainly won’t get any bite on my gear drives now.
I thought it might be. Looks sharp as hell (no pun)! I’m gonna use a comp 95. Hopefully it’ll be a solid deck to build upon. Hadn’t considered needing to modify to prevent bite. Not using gears tho, so might help to make a difference… excited to see this whip in all its glory!! Any recommendations for the hubs? Mine came with twistars which I likely won’t implement. They have the pro version of the rockstar or 5star which I’m considering, but not sure if it’s necessary.
Sorry to derail the thread people!!
I built a Comp 95 for my GF and it works worth the 72T pulleys MBS makes, running Matrix II and 5 Stars
