Hi everyone, I’m sorry that it has been delayed for two years. Now I will introduce the 12S BMS that I said before.
Today I would like to introduce to you our return member-MAXKGO BMS (referred to as MKBMS)
First of all, as mentioned before, we tell you frankly that MKBMS is developed based on BMS open source materials. Our engineers made a new hardware design based on the combination of DieBieMS and ENNOID BMS open source materials. Here, special thanks to the developers of open source DieBieMS and ENNOID BMS.
In terms of hardware, we mainly innovate in terms of size, circuit layout, boards, etc. We designed the circuit layout to be more compact, making the size of the BMS smaller, only 117.4 x 47.3 x 29.3mm.
MKBMS uses automotive-grade locks and reverse bayonet to prevent wires from loosening easily. The PCB board uses 6 layers*2OZ=12OZ copper thickness, which has better current flow capacity.
As before, We use an aluminum alloy shell, and the surface is treated with black sandblasting and oxidation to achieve anti-oxidation and insulation functions.
MKBMS has overcharge protection, overcurrent protection, balancing function, temperature protection, etc.
Supported batteries: Supports almost all lithium batteries such as lithium-ion batteries, lithium polymer batteries, and lithium phosphate batteries.
In order to facilitate everyone’s use and reduce the shopping process, our BMS boards will be shipped with switches, displays, USB and other wiring accessories. You can see the pictures below or browse our website for more details.
MKBMS has the following BMS specifications:
High and low voltage main control board and slave control board 12s, 15s, 18s. They also come with switches, displays, USB and other wiring accessories. Of course, there are also 12s 24s integrated boards and other BMS.
In the future, we will continue to improve BMS and sincerely welcome your suggestions and ideas to make BMS better.
Last but not least, thanks again to BMS for open source. We are committed to paying $5 to the ENNOID BMS open source for every BMS sold. thank you for your support.
Free shipping over $59 to most countries. Hope you enjoy MKBMS! ![]()
Purchase link: https://maxkgo.com/collections/all-in-one-bms-board/products/6s-12s-200a-smart-bms-for-esk8-consumer-robot-e-car-e-board -mkbms-all-in-one-board
