faaaaaaak dat looks like them…
I was just coming back to ask you where to find a jack…
I’ll report back when Ernesto gets back to me…
Maybe this thing?
https://www.mouser.com/ProductDetail/CUI-Devices/PR-2155?qs=%2BEew9%2B0nqrDXc8k%2FA8GUUQ%3D%3D
It’d need some epoxy work in order to use it
Maybe solder work
edit: can confirm, solder and glass-infused epoxy are what is needed to mount them
BRB… I’ll go take a pick of the jack…
EDIT:
@b264
It’s a pretty neat little barrel jack almost the same size as a 5.5mm jack… Has a threaded outside and the port is protected from the outside environment with a tread on cap that looks similar to a tire valve stem cap!
That looks like the jack I used on my Evolve Carbon AT gen 2 deck build. I can try to dig that up
I’m NOT going to stick my metal vernier calipers in there to measure it…
similar… but much deeper… I can’t even see the positive pin in mine
Ok I got that thanks!
