daly has 11 wires and the JST’s have 6, is this correct?. bottom Lipo is main negative and top is main positive
the BMS wires will be soldered to a JST adapter first like the image below. would it be safer to heat shrink the excess wire or remove the pin, assuming the diagram above is correct
