Yzpower having a massive Christmas sale on most chargers
I received mine in just over a week alll the way from China and they are really some of the best chargers on the market
https://yzpower.aliexpress.com/store/group/YZ300/2217102_511953664.html?
They have all different voltages and amps
Just saying for anyone who was looking
Chaki
December 16, 2019, 11:15pm
2
I have this model https://www.ebay.com/itm/Waterproof-50-4V-6A-Lithium-Battery-Charger-For-12S-44-4V-Li-ion-Ebike-charger-/283494884786
No problems what so ever and not loud. I can hear it yeah but it not annoying.
I recommend YzPower chargers
Halbj613:
Regular price is ~50US
pjotr47
December 16, 2019, 11:17pm
3
That is just the standard price. I like btw the Wate chargers more.
€ 34,11 32% Off | 50.4 V 4A Charger 12 S 44.4 V E-Bike Li-Ion Batterij Smart Charger Lipo/LiMn2O4/LiCoO2 batterij Oplader
https://a.aliexpress.com/nykSIaJm
Is 5.5x2.1 or 5.5x2.5 the standard barrel jack?
Charges to full 50.4v? I think my charger isn’t allowing my battery to reach 100%. Would be nice if I had one that allowed full charge.
pjotr47
December 16, 2019, 11:19pm
6
I use always 2.1mm jacks. Due that you can also use a 2.5mm charger on that jack.
So 5.5x2.5 for the charger (male) end is always a safe bet?
Myke
December 16, 2019, 11:27pm
8
What does it charge to? Are you sure your cells aren’t just out of balance and you just need to leave your battery plugged in for a day or so ?
Chaki
December 16, 2019, 11:51pm
9
Open it upp i can slightly adjust the volts. Just measure it with a bolt meter and u will be all set.
Hits 50.4, stops charging drops down under 50v over some time. All p groups are .01v of each other. Not sure what leaving it in would do considering it stopped charging.
Myke
December 17, 2019, 12:16am
11
P groups only balance when the charger is plugged in at full charge
Even if no current is going through?
Myke
December 17, 2019, 1:21am
13
It balances slowly. Depending on what bms you have. The d140 bms balances at a whooping 84ma .
janpom
December 17, 2019, 3:00pm
14
I like to think of the charger connector as female since it has the hole whereas the counter-part has the pin.
As you would expect, 2.1mm pin can be inserted into a 2.5mm hole but not vice versa. Mating the 2.1 male with 2.5 female may result in sub-optimal contact so it’s not ideal but it does work.
In a nutshell, yes, getting 2.5 on the charger is your safest bet. For best results, get a 2.5 counterpart as well.
rey8801
December 17, 2019, 3:18pm
15
Thanks just ordered a 16s charger
