Hi,
YongESC V6 50A VESC6-based for Esk8/Ebike and Perfect replacement for V4.12
Is there a reason for it to not have direct fets?
The MOSFET model is IRF7530.
The case is identical to the Maytech SuperFOC case. What else might be an exact copy, I wonder?
You see, mine is the original.
It looks like a drop-in physical replacement for the VESC 4.12
YES, Perfect replacement for V4.12.
It would be helpful to use consistent and precise language here, since you call out both the VESC6 as well as the 4.12.
Based on the DRV chip, it can be concluded that this is using the VESC6 architecture, but in a smaller footprint than what’s usually seen. This is what I’m assuming your intent is when you say “perfect replacement for V4.12” If not, it would be useful if you expanded on your intent for those words.
You may also want to change the model name since FESC is typically associated with Flipsky
Thank you very much for your advice.
Flipsky ESC usually starts with FS
YES,
However, the board is the original design.
You aren’t specifically mentioning it in your description (in words) but the RX/TX pins are in v4 position I would guess.
Direct replacement of V4.12
@moderators op link now scam
Removed link from OP. Thanks for bringing this up.
