Does anyone have any idea what screw or bolts (and sizes) hold these Xcell hubs together? and where to get them? We are trying to find replacement screws as apparently the box was missing the hub screws…
Cheers!
Cheers!
I believe its M4x30 or M4x35, not too sure exactly. Longer for the ones to mount pulleys of course.
Looks like that left front hubs bearings exploded
Thanks @Ac53n
Nah the rims were never used but the bearings were pulled out for what reason I have no idea…
Any idea of the bearing size for a replacement?
I believe they’re 12x28x8 stock. The product page lists 6001 2ZZ specifically if you want an OEM replacement.
You’ll probably be able to read the size for the bearing somewhere on one of them. Either in the seals or inner/outer race’s rim usually.
6001 2rs are just better for skateboards. Rubber seals.
Thank you @Evwan !
