Hey guys i have some stuff i wanna trade for stuff to finish my build. I need a 42v 4 amp charger, any remote compatible with a focbox unity, and a direct drive kit capable of getting me to 35mph as well as the little motor interface thingy that goes with the enertion raptor 2.1 setup.
Anzo a-1 pro, needs remote, battery (have old one to go with), and charger
Backfire zealot s esc and remote: pulled from old setup when battery took a dump.
Chargiot bomb esc and motors: worked when pulled.
I also have a kahuna creations 43in drop deck that’d make a sick diy build
I would charge that enertion pack slowly. The pack is super old by now and the stock BMS is known to die. Also the original enertion charger might say 4A but it actually only outputs 3
Those 30q cells are known to have balance issues after 5+ years of age.
Charge slowly and supervised.
Not much people here will trade DIY stuff for china pre built parts but i wish you good luck !
Ride safe
Thankfully the battery is healthy, my charger just took a shit lmao
How would one charge one slowly? A buddy of mine has the same pack and is experiencing issues
I can assure you that battery is not healthy. Did you even measure your balance wires ?
By using a charger with a lower A rating
I did, as well as check each cell group
