@BillGordon was nice enough to let me know that Sharts apparently is in need of some attention.
Sorry broseph I’ve got you on ignore.
i’m dying to know why boosted board includes 2 receivers if not for redundancy.
then you can derelict my balls…
Is there a preference towards XT60 vs XT90? I understand that of course XT90 can handle more current but are there setups out that run at cont +60A?
Brian does not have Boosted’s engineering department to design an integrated dual radio module redundant solution. I can guarantee one side doesn’t drop out if one of the radios does. It’s an intentional design, not a hobbyist solution.
If you do understand the foundational difference between those two solutions, perhaps we should have a longer talk about why it’s rude to waste people’s time.
but you ignored my other post about which gives the bigger jerk
That’s life buddy. Back to ignore list you go.
It’s not been fun.
i have a highly objectionable picture of what happens to a forum member when their one and only receiver drops out for a split second while braking at high speed and they’re days away from a kickstarter campaign…
its easier to be an ostrich than an owl…
Says the guy who signs on only to attack people who are trying help others.
{grabs popcorn}
what’s the point of putting two of the same radio in a device if its gonna fucking disconnect.
//////SSSSSS dont actually answer me
Again Brian, pointing out that you’re giving uninformed, potentially dangerous advice to newcomers, isn’t attacking you.
It is possible for you to be wrong. Give it a try sometime.
PSA: running dual receivers is in no way proven to increase safety, and 100% undeniably adds a second point of failure that persists 24/7.
torx > hex
poll: would you rather be on a board at high speed downhill when one of your wheels fails to brake or both?
Again, fringe failure case protection in exchange for a permanent increase in failure points. You’re not stating the caveat.
It’s pretty simple.
oh?
10 char
Do you want the attention or not Devin?
