lmao you’re not wrong
Pending for the next 2 weeks probably, someone semi-local says they’ll trade it for a 1200 mi OneWheel XR, who got the better deal?
Update though, motors have been filed to be smooth then wrapped in reflective tape, motor mounts have been epoxied and pinned in place for a top mount configuration
$1700 with a 3x external range pack in a top mount hard case…any takers? My guy got stuck in Texas so I’m back to selling the skate for cash so I can buy an OW XR with cash
As much as I love this board it just doesn’t feel right for me and I really want to get an OneWheel XR, and I don’t have enough cash on hand to buy one which means this HAS to sell first. There is nothing wrong with it and I will warranty (free service) the battery for any inexplicable failure for the first 4 months. The top end is 30 MPH and you’re looking at 20 miles of range.
This is the absolute lowest price I can go, and it’s non-negotiable. $1000 shipped in the 48 states, buyer pays G&S fee and shipping insurance since they are optional, shipping to Canada is possible and I’ll cover the first $40 of shipping. It comes with the remote and a US socket charger, it’s ready to go and you can hit the streets the moment you get it. If you’re willing to meet within a 50 mile radius of Newark Delaware you can test ride it and take it home with you.
Realistically if you wanted to make this yourself it’s around $1800 in parts and battery building, the whole board has about 100 to 150 miles on it and it’s in good shape, as far as I’m aware this is an amazing deal. To be up front and fair the motors and mounts have some damage from when the wheels were smaller and it was drop mounted but there’s nothing wrong with them, the ESC and wheel pulleys have some extra wear because I got them used but they are none the worse for wear and it’s nothing to worry of, the deck is the prototype variant but all that means is I had to remove a little material for the battery to fit (that expansion comes stock not so it’s not like it’s weak).
I can sell it with a brand new 12s4p P42A with a smart BMS in a waterproof top mount case with a built in BMS as an external battery, I would wire in a parallel combiner to the ESC so as long as both are the same voltage you can plug it in and triple the range, plus it has enough current to max the motors out at 3000W each. If you buy the board I will include it for $600 at no additional shipping cost and will wire in the combiner. The mounting solution is up to you, I’d suggest casing some flats on the deck with epoxy and adhering with dual lock.
Part | Name |
Battery Building | 12s2p single layer |
Bearings | zealous classic |
Belts | 320mm HTD5M 12mm |
Bluetooth | metr pro unity |
BMS | ltt 12s 20a |
Bushings | riptide 93a krank with washer |
Cells | molicel p42a |
Charger | yzpower 50.4v 2a |
Deck | tomiboi v2 puddin pop prototype |
ESC | enertion focbox unity |
Hardware | misc bolts/nuts/washers/screws |
Motor Mounts | dickyho |
Motor Pulleys | dickyho 15t steel |
Motors | bkb 190kv 6354 |
Remote | flipsky vx1 |
Trucks | caliber ii |
Wheel Pulleys | bkb 44t |
Wheels | bkb 97mm |
This board is so much nicer than what you can get with a pre-built for similar $. @ZachTetra I hope somebody takes snaps this one up soon!
How long is that deck?
38.25” I believe
Clean build!! Will recomend
Thank you!
