Here is an installed but unused set of 8mm 55/11 Newbee 4GS Gear Drives.
They didnt work for a build im working on so selling them off. They have zero miles on them.
Things to note:
They need motor pinions. Originally bought with 8mm shaft versions. I’m including the original pinions but the pressed on bearings are broken off. So it may be possible to repair them or even run them without bearings possibly.
There are only light scratches on anything as they only went through the install process.
I had an allen wrench tip break off in the set screw of the 22mmx22mm adapter that connects to the truck. I had to drill out the tool tip but was able to completely avoid damaging the set screw. So set screw functions perfectly and drilling marks will be on the bottom of the board. See photo below
They have been put together with blue loctite on the gear drive housings and the gears have been greased with red n tacky.
Comes with
Housings
All internal gears
Two different sets of motor mounts (silver and black in photo)
Carbon Fiber shims
3 sets of TPU adapters from Newbee
2 22x22mm truck mounts ( bought to work with duality trucks)
2 MBS patterned wheel adapters
All hardware for assmembly.
$250 shipped anywhere in the lower 48 US states
