I’m worried that I may forever regret selling this board, but here it goes…
Everything is brand new with exception to the deck and enclosure. The deck and enclosure has seen about 1k+ miles and was purchased directly from Flux Motion. Other than a few scratches on the bottom of the enclosure, there are very little signs of wear. The board has been taken for a few rides to make sure that everything works since the most recent rebuild with the new components. This is the most refined board I’ve ever ridden. Located in Albany, Oregon USA.
Specs:
Top speed: 43-45mph (depending on % charge)
Range: ~50 miles (depending on rider weight and riding style)
Total max force acceleration: 695 (Newtons)
Weight: 47.5 lbs. (21.5 kg)
Parts:
DIY Flux Motion AT1 deck and enclosure (blank deck/no graphic)
BN 310 Split Angle Channel Trucks (+5 in the front, -5 in the rear)
Riptide Lacroix Bushings
MBS Pro II XL Hubs
200x50 CST tire and tubes (extremely well balanced)
Radium Titanium Axle Nuts
NewBee 55/11 4GS Gear Drive
SKP/Reacher 6485 151kv Motors
18s6p P42A battery w/ LLT smartBMS
MakerX D100s (w/ micro USB flush mount external connector)
Zmote Torch Trigger remote
10A Charger (w/ WM-20 connector)
Okay… I’m considering parting out this board. It would be helpful to know if there is enough interest before I commit to taking anything apart. Here is how I would propose splitting it up:
Item 2 (Trucks): -BN 310 Split Angle Channel Trucks (+5 in the front, -5 in the rear)
-Radium Titanium Axle Nuts:
No bushings included. Less than 50 miles on the trucks. Tiny indentation in the clamp area from the 4GS drives. No scratches or scrape marks. In new condition. $150 OBO (USD) w/ free shipping in the CONUS:
Item 3 (Wheels) SOLD -MBS Pro II XL Hubs
-200x50 CST tire and tubes
-MBS 12x28 Bearings
-Boardnamics Bearing Spacers
Most balanced 8" tire I’ve ever ridden
Tubes are slimed
2 hubs have longer m4 bolts for the 4GS adapter
Bearings have loctite in the bearing seat to prevent clicking
Less than 50 miles on the wheels. In brand new condition. SOLD:
Item 4 (Drivetrain) SOLD -NewBee 55/11 4GS Gear Drive
-SKP/Reacher 6485 151kv Motors:
All connections have loctite and gear assembly is greased
No scratches on motors or cases
Less than 50 miles on the drivetrain. In brand new condition. SOLD:
Item 6 (Remote) SOLD Zmote
-Torch version. This is the fancy version with all the lights and battery telemetry.
-Remote battery included.
-Deadman switch deleted.
-Clear outside edge with black accent grip.
-No wireless charging.
-PWM mode.
-PH2.0MM JST (plug and play w/ MakerX D100S).
-Shrink wrap removed and covered in electrical tape instead. SOLD:
