USA
Grinspector Battery Testing Station w/ 13.6 ohm
For more info visit:
The battery grinspector is a battery test station designed specifically with ebike shops and dedicated DIY builders in mind. Unlike bulky rack mounted commercial testers used in industry, the Grinspector is just a small base station controlled by the familiar Cycle Analyst device running a custom firmware. You simply plug in your battery, a charger, and an appropriate load for discharging the pack and the Grinspector software will allow you to cycle charge and discharge the pack while logging the results on a computer. Basic Layout of Grinspector Battery Tester
This provides you with the pack’s available capacity in amp-hours and watt-hours, internal resistance, and a graph of the discharge curve profile. For ebike shops it can serve as a means of doing quality control on inbound batteries and for troubleshooting and warranty testing customer packs. As an added plus, you can set the station to automatically recharge the batteries to 30% capacity at the end of the test so that they are in the ideal state for shipping or storage.
**Price: $450 plus shipping
