WTS • [GER] - Strong 24k Watt Complete Board
Description:
Video about the board: https://youtu.be/nJLqdKuiS40
Extreme acceleration. Max speed 105 km/h
Acceleration similar to a 700 hp car.
The creation of one of the world’s most powerful electric skateboards!
I’ve been building electric skateboards for 10 years. It all started because I kept buying new skateboards and was never satisfied with the performance, or the performance was okay, but the board was far too heavy and unwieldy.
That’s why I started delving into the technology to build a skateboard with more power than I could control. It also had to be as light and sleek as possible, like a Formula 1 car: lots of power, yet light and extremely agile in corners.
This skateboard was created using very high-quality and high-performance components. For example, CNC-machined lightweight gearboxes, rims, and a specially adapted fiberglass battery housing that takes up only the bare minimum of space while remaining flexible enough to provide the board with suspension, which is crucial for absorbing road imperfections at high speeds.
Don’t worry! The controller is fully adjustable, allowing you to seamlessly adapt the power and braking force to your needs. You can switch between different settings at the touch of a button, such as beginner mode and extreme power mode.
The skateboard deck is custom-made in Germany. It features suspension and is also very laterally stable for high speeds. A longer wheelbase provides stability at high speeds and during extreme acceleration.
White front light. Red rear light.
Anti-sparking and fuse protection, overheating, overcharging, and undercharging protection.
Motors = Sensored outrunner brushless DC motor, battle-hardened. 2 x 6000 Watt
63100 140KV 6000W
TORQUE 23252.9 mN.m
ESC = Powerful Electronic Speed ​​Controller - Ubox 16s/75v 200A VESC
Adjustable power curve. For example, smooth acceleration or extreme start power that can even lift the front wheels.
Power controller = 2.4GHz Screen Remote Uni1 V2 compatible with VESC.
Power and speed limits can be changed. Battery level indicator.
You can precisely control the throttle and brake with your thumb. The brake is also motor-controlled and can be set to a powerful setting to completely stop the wheels and perform slides. Reverse driving is possible.
Powerful Battery Pack = 16s/6p, 21700 Molecular cells P50B.
96 cells total
67V - 30,000mAh
Maximum discharge current = 24,000 watts. More than enough :wink:
The battery can recharge while braking or going downhill.
Gear Drive = To transfer power to the wheels, a CNC precision gear drive from 3D Servisas is installed. No power slippage or broken belts.
Axes = Also CNC custom-made by 3D Servisas. Designed for stability and high speeds. Adjustable stiffness.
No speed wobbles.
Rims = Offset Megastar from Trampa. Lightweight precision CNC aluminum rims.
165mm pneumatic wheels = 45 PSI, 3 bar. Designed for speeds up to 120 km/h.
You can, of course, test the board if you pick it up yourself.
It is also for sale on eBay Kleinanzeigen:
Price (EUR):
4000
Images
