Bump bump
Dropped to £1650
Need it gone
Bump bump
Dropped to £1650
Need it gone
I would like to buy the trucks but not with the gear drives. I already have Moon gear drives and i use motors with 10mm shaft. Maybe someone takes the gear drives… ![]()
If you find someone else
But I doubt anyone will want just the drives
What trucks will the gear drives fit just these?
I think just these but you would have to ask 3Ds
Would this drivetrain work 9n a mountian board?
Freeroll is less important on an eMTB…
LOOK I’m helping. ![]()
Should do
The lacroix is pretty much one
I think that style of fb320 is 19x19? It isn’t the more common 22x22 anymore
Prob @Skyart would know
He has dealt with this quite a bit
It is 19x19 I think
Edit 20x20
I was close. ![]()
I have 20x20 adapters for my M1-AT drive. Tis’ is all.
So, no one in this thread wants to take the gear drives and i’ll take the trucks?
Possibly we have someone for the drives and motors
Working it out
Also gotta work out pricing
I hope your keeping at least the deck and enc for yourself to build something you do like! ![]()
EDIT: and maybe you need your tag line changed to ‘importer of fine esk8 gear’ ![]()
Wasn’t planning on it.
I thought this deck can only be used with channel trucks
Or maybe I wrong
some adj baseplates and maybe some BN 270mm hanger wouldn’t bite too much
Maybe
I doubt it though
I may save up for a stooge sled
Or build something a little more original (wanna attempt to build my own direct drives)
N
can I suggest you make a little more effort to maybe go and try something before you buy it ![]()
