I’m clearing my office/workshop and there’s a lot of items that’s been sitting on shelves for way too long. It’s time that somebody makes a better use of it.
I’m probably living 4 years in the past regarding esk8 prices. Feel free to tell me if I’m way off somewhere or make me an offer.
I prefer to ship within EU and only orders worth 100 EUR or more. I’m based in Brno, Czech Republic. This is probably a long shot but if anyone wanted to come over and pick up all of my stuff, I’ll give you a huge discount.
Reachertech 6385, 170 kV, sensored
Some scratches but fully functional. Come with custom spacers that level out the protruded bearing.
100 EUR
Enertion Focboxes + 3Dservisas heat sink
These are very old but still fully functional.
125 EUR
Landyachtz EVO 40” + Eboosted enclosure
From the legendary 4WD Bioboards Thorium. Deck took some damage on the tail – see pics. Note that the enclosure has cutouts for cable routing both at the front and back. There are also holes after the original charging port and battery voltage indicator that I sealed with epoxy – well sealed but doesn’t look great. Deck nose has a hole for DAVEGA cable.
(Please ignore the trucks + mounts on the pics. I was lazy to unmount them. I can take better pics if needed.)
150 EUR
3DServisas FatBoy CNC raw ALU 240mm SurfRodz + Hammock adjustable baseplates
Great condition. I bought these used from @Lobap but I barely used them.
200 EUR
Surfrodz TKP 177mm, raw, 10mm/8mm axles
Great condition.
150 EUR
Surfrodz TKP 177mm, black + red, 10mm/8mm axles
Whoosh mounts not included – separate item (see below) but I would prefer to sell both together.
125 EUR
Xtla mounts for Surfrodz TKP
Some damage on the inner side of one mount caused by me being stupid. Once motors are installed, this should be almost invisible though.
These would go great with the raw Surfrodz TKP above.
125 EUR
Whoosh mounts for Surfrodz TKP
Some scratches. No damage that affects function though.
These would go great with the black/red Surfrodz TKP. ![]()
75 EUR
Random 40” drop down deck
Scratched bottom. No problems otherwise. (Trucks not included. I’m happy to include the x-brackets though.)
35 EUR
Evolve wheels + pulleys, 150x50 tires
2 original pulleys (66T), 4 custom 3D-printed (54T).
75 EUR
Trampa Superstar wheels, 155x50 Metroboard tires
Installed: Off-set spoke support spacers for 608 bearings and 8 mm axles.
Also included:
- spacers for 6001 bearings and 12 mm axles
- centre-set spacers for 608 bearings and 8 mm axles
100 EUR
Evolve 7” tires + tubes
25 EUR
Trampa Urban 6” tires, 12 pcs
40 EUR
Toqueboards 110mm wheels, kegel cores
Great condition. (Picture TBD)
100 EUR
Alu pulleys for kegel-core wheels, 40T
40 EUR
Arbor PocketRocket, complete skateboard
Not really esk8 gear, though you could probably use the deck for a compact esk8 build. I bought this for my son when he was 6-7 yrs. He rode it about 3 times. It’s like new.
50 EUR
Elofty direct drive 60 kV + front truck
Kegel wheel adapters. Works great with the TB 110mm wheels.
Visual condition not great (as can be seen on pics). Sensors no longer work. The drive does work well sensorless though.
I have used this drive a lot and I really liked it. It’s very silent. If you want something simple and cheap for a low power build, it’s perfect.
50 EUR
