Parting out my current board and some other parts. Don’t have time for it, need finances and free up some space. In the past year I have been out like 5 times. Haven’t even ran down the soft MBS red tires that I already bought used. Parts selling here are mostly used.
Prices are always open for discussion, shipping cost according to Slovenská pošta - Price list
Deck & Enclosure
sold
Description: Deck Globe Sledgehog Fibercarve 37.7 (filled truck holes, painted) with big fiberglass enclosure. Enclosure comfortably fits double stack of NESE 12S8P with foam padding. I made aluminium extensions so I can fit 8 inch pneumatic wheels with torqueboard 218mm trucks. Some wider trucks like BN270 or some DKP might allow you not to use that extender, but I haven’t tried it. 8 inch wheels have good clearance, smaller wheels might need some extra risers or remove the gasket from the enclosure for thinner one. There are scratches, but no cracks. Maybe watch this video to see how the enclosure was made: https://www.youtube.com/watch?v=MscoSBO1gzA
Price (EUR): 35
MBS Rockstar Pro wheel set
sold
Description: Set of 4 MBS Rockstar Pro hubs including 2 used red MBS tires, 2 used black road tires, 4 used tubes filled with anti-puncture goo, 2 used 60T PETG pulleys, 8 used 6001RS bearings and then also 2 new black road tires and 4 tubes which are not on photos, will add photos later.
Price (EUR): 90
Torqueboards 218mm trucks
sold
Description: Including baseblates, 3 sets of bushings, some washers, nuts, spacers, risers. Motor mounts are sold separately. One truck has dent from motor mount thaw was screwed and clamping motor mounts might be sloppy there. However other truck is fine for clamping motor mounts.
Price (EUR): 60
Motor mounts
sold
Description: Pair of motor mounts. As seen on photos. It has dickyho idlers. Bit dirty.
Price (EUR): 30
NESE 12S8P 18650
Description: 12x 8P 18650 modules printed from polypro PETG plus 3 more uncut tabs.
Price (EUR): 60
LLT 12S 120A bms
sold
Description: It has bluetooth so you can use it with xiaoxiang app. I wired it with switch so you can turn on and off your board. Once again currently in battery pack, but it will go out.
Price (EUR): 30
Samsung 30Q cells
Description: 96pcs used in the battery pack. These are 30Q cells from nkon that were used in 3 packs which I disassembled. Originally purchased 2019-2020 from nkon. Nickel was grinded off without damage. Two marked with red dot have some minor bending to them (I was discarding cells that had minor bending, but in the end I had to use 2 of them in my pack). I rewraped them, because glue in the packs damaged most of original heat-shrinks. Yellow, white, blue dot indicates which pack they came from. I tested them for capacities so I can distribute them evenly in my pack, but these are not full capacities.
Price (EUR): 1eur/pcs
Charger 12S 6A YZPower
Flipsky 6354 motors
sold
Description: Pair of 6354 motors. Some scratches from flying rocks, but perfect condition.
Price (EUR): 70
BKB 6374 motor
Description: Working as it is, but some cleanup/maintenance would not hurt.
Price (EUR): 25
Unbranded 6374 motor
Description: Should be from BKB too, but I’m not sure, it has no branding. This one works as well, but it has clicking sound when turning so it 100% needs opening up and checking.
Price (EUR): 15
Flipsky FS4.12
Flipsky VX1
Pulleys 16T pair aluminium
Pulley 16T steel
Price (EUR): 4
Pulley 15T steel
Price (EUR): 4
Pulleys 40T pair
Description: Torqueboards 40T 15mm aluminium for abec style wheels.
Price (EUR): 25 for booth
Pulley 36T single
Description: aluminium for abec style wheels
Price (EUR): 10
Belts
Description:
15x410 2pcs (used) - 1,50€ per 1pcs
11x270 4pcs - 2,50€ per 1pcs
15x275 1pcs - 2,50€ per 1pcs
9x280 8pcs - 1,50€ per 1pcs
12x295 2pcs - 2,50€ per 1pcs
15x295 1pcs - 2,50€ per 1pcs
11x300 2pcs - 3,00€ per 1pcs
15x300 3pcs - 3,00€ per 1pcs
12x340 1pcs - 3,00€ per 1pcs
Price (EUR): 20 for all
Truck nuts
Description: over 30pcs
Price (EUR): 2 for all
X-things old school
638 bearings
Description: Set of 8pcs. Used, but they are like new, there is no play. If you want to use MBS wheels on 8mm axles.
Price (EUR): 16 for all
