I’m selling the Titan V1 prototype battery.
It is hand build by our engineer in Germany.
Here you can watch the hole building process
There are 144 Samsung 18650 30Q batteries with about 10 cycles build in. The cells are less than 1 year old. The exact date is on the pack.
You get 200A of continuous power out of this pack, or 400A motor current (20kW).
1600Wh are good for 80-160km of range.
The DieBieMS can keep up with 240A total phase current or 120A max battery current. The fuse didn’t blow up once on those settings.
It is screwed on a 3D printed sink which is glued to the enclosure.
Everything is packed compact into a 57x25x5cm black painted aluminium enclosure (needs a fresh paint, if you care about optics) with cable routing, charging port, on/off switch and and holes to screw on the VESCs.
It’s basically a plug and play battery kit. Just throw your VESCs inside and you are ready to go.
