Smorgasboard going up for sale
Here is the Good
Tramps HS11 17Ply
12s5p QB26800 35AH battery (40-50 mile range) 100amp discharge Smart BMS
Kaly Gen 1 straight cut gear drive 1:4
TB 6380 170kv motors
Trampa rear truck with trampa barrels
MBS metal matrix 2 front truck with my favorite purple bushings (they are actually reds, will also include oranges)
Black superstars with kenda 8" tubes and tires
VX2 Pro
now for some pics
Some battery build pictures
Had to move the BMS around a few times to find a good spot for it. As you can see in this picture the middle enclosure is a bit cocked this is because the bms is in the side board not to he riden in any kind of water/rain
If anyone is interested in having this battery reconfigured to top mount will do this for a small charge.
Board does not come with a vescs, you need to get your own I recomned something that can handle 100amps continues, this is currently my set up on it, and it runs amazingly!
Here are a few videos
Telemetry is from metr
That last video I had older motors on it that were pretty loud also 9" tires. So top speed was a bit higher.
The board will do over 40mph, however after 38 wheels start giving a bit of a wobble, so I dont often push it to 40, I recomend figuring out how to balance those 8" have not cared enough to do that tho, mostly I cruise in the low mid 30s
Will part out if no one wants it in the next few weeks
Feel free to ask any question!
Thanks for looking.
