Evo 40 (50$)
Eboosted double stack enclosure ($50)
12s10p 100amp battery made of 3200mah cells ($650)
D140 charge only bms
12s 4amp charger ($50)
Trampa Vesc 6+ x2 with silicon case ($500)
TB6380 170kv x2 ($150)
Front truck 3dservisas 230 ($80)
Rear truck boardnamic cnc ($40)
Dual bornamic mounts with idlers ($20)
395mm belts ($5)
16t motor pulleys ($10)
TB AT hubs with 8" roadie tires with 62t pulleys ($100)
VX2 remote ($60)
Did I mention the 8" tires?
Total $1600 plus shipping!
Individual prices listed are part out prices, will part out in a few weeks if complete is not sold
This board gets up to 42mph with me on it, did not have the bravery required to push it further lol! As far as range, the longest ride I have done is 25 miles, after which I succumbed to cramps! Voltage was 42 volts after 25 miles.
Most recent ride was 10 miles with ending voltage at 47.2, battery charges to 50.4 volts.
Solid build, reliable, plenty of torgue, really good top end.
The bad
Lots on unessasary holes in the enclosure, needs some love, not the best job with inserts. The battery is really big, so this board weighs 40lbs. But you get plenty of range! Lots of hot glue everywhere keeping things in place!
