This charger is looking for a new home, because I got a Meanwell 600W led driver for charging.
Voltage is currently set to 51V! (I can change it if requested)
Asking: 40€ shipped
Out of curiosity, why would you set it to higher than 50.4V?
Not in EU, so i wish you luck with your sale. Im wondering if you have a link to this charger? I have been looking for this exact YZpower charger for a while now, only found other models or metal case models with fans that are larger, etc.
I think it’s so you can charge faster but you need to keep an eye on the voltage towards the end
Because I have a DieBieMS, it requires higher input voltage to auto start charging.
Huh, you’re right – they’re all gone from aliexpress and ebay
Maybe they’re out of stock; It took like 4 months for me to get my charger I ordered in January.
how do you change the voltage on these? I have the 10s version and want to make it 12s. thanks
If you open it up, there should be a small pot inside you can switch but there usually is a limit to how far you can turn it up.
You can’t turn 10s charger into 12s. The pot inside can only adjust it like about ±1V I think.
Edit: mine didn’t go above 51V
Correct. But there isn’t enough play to make it 12s.
They are usually adjustable from 39.9 - 43/44v
or 49.9 - 55v
I got it from Aliexpress last summer, but I wouldn’t recommend buying anything from there at the moment. Shipping will take forever now!
That’s a 200w charger pretty good!
Its close. DieBieMS reports actually 3.8A while charging, so tbh around 190W
My brother and I in Latvia are receiving our Aliexpress goods as expected…
