Well, this might be the worst time to be in the market for a MTB deck.
Basically, as the title says, I am looking for a MTB deck in the US that is in stock. Basicly the only requirement is that it can take Matrix 2 trucks.
Does anyone have one that they are willing to part ways with?
Built in flares for your feet so you can do what you do with extra control and this eliminates all falling. You will not fall with this much control. You still need a helmet tho
Thank you. They are $275.00 without shipping and believe shipping is under $50.00 in us.
Just shipped a custom out last month to a member here on the forums. Was a super fun process.
The price does not include a custom mold. So would have to use a current mold but shape of that
deck is up to you. Color is also up to you or blend of colors. Now if you need inserts binding holes
pre-done that I can also do but recommend setting your own bindings. I hate the default but maybe thats
just me. If it gets really special in the shape or crazy colors the price may go above that but in most cases I have no issues with that as my price.
Example The Yellow or Blue Deck, $275.00 would be fine.
I have a blemish I can let go for $150.00 shipping is like $20 or very close to that.
The blemish had the wrong holes drilled, then filled with dowel rods then re drilled in a new area that
is not filled with dowel rods. So its a sound deck but I consider it a blemish.
This is also a 10ply deck, so that is also something to consider.
It is strong but the length and shape helps to create some flex. Not flex like a noodle but its
not a super stiff deck despite the 10 plys.
How wide is it where your feet would be?
What is the tip to tip length?
In terms of flex, would it be comparable to? I know it is a bit of a tough question. I am 95kg and will have a somewhat large battery in the center. I don’t mind flex, but I just don’t want too much.
If I were to re-paint it, what type of paint would be good? I don’t think even I can pull that color off
I’ll gets specs when home. On the rd now. It’s close to a hero bro in specs but not 100% same. Flex will be that of a MBS so not Trampa flex. An should not bottom out when jumping from standing. Now if you send it off a 8ft kicker to flat expect it to bottom out before it breaks. That’s by design. Hard rock maple is the layup.
You see, I had to stare at that color for 2 of the most painful weeks of my life when I was in the hospital. It physically hurts me to look at that color.
