[WTB] [US] MBS Aluminum Hubs
I’ve been working on revitalizing an old Trampa Holy Pro setup and I’ve hit a roadblock with finding motor mounts compatible with Trampa spring trucks in the US to replace the fiddly ones it has on it atm.
The current tariff situation has made me gunshy about ordering from Trampa or Idea directly (the two options I’ve found for new) & it’d be great to pick up some used anyway. Would also def be curious if there’s another source or well-known DIY adaptation for other mounts I’m missing for a possible solution.
Hoping to get to a 4x4 setup eventually so two sets would be the goal and matching especially.
Also interested in 2 more aluminum bolt on style pulleys for the Superstar hubs to get to 4x4 - I currently have a pair of 66t and a pair of 78t.
I have a set of Trampa mounts that fit vertigo trucks if you are interested.
Wanted to bump this thread because since thanks to Ozzy the Trampa mounts were aquired, but now I have some other truck styles to try as well.
I’m interested in belt drive motor mounts for 20x20 and 22x22 profiles if anyone has some to put up for sale.
I have some 22x22 Apex mounts leftover form their chain drive laying around somewhere if you don’t need an idler. Let me know if you’re interested and I’ll send you some pictures.
Sure - I’d def be interested to see them - I’m hoping that profile will fit Newbee RTKP trucks I’ll have soon. I have some Tito Duality mounts on Apex PKPs atm so if the Titos fit the Newbees when they come in I could shuffle them across too.
An edit to add a longshot - If anyone has Trampa Bull/Stash Bar setups they don’t need I’m interested - I just was able to mount the set I had already to my current 4wd and making it even more ridiculous and symmetrical would be fun.
Bumping because currently I’m looking for a pair of 6355 or 6374 size motors 170kv or higher preferably with a 8mm keyway shaft. Just finished up / initial test on a street pneumatic build with 6355 but they’re 125kv so a bit sluggish/hot on 12S. The Flipsky 6374 190KV or SKP 6355 205kv seem like the options I’d buy new for this.
Also I’d still be interested in 20x20 size belt drive motor mounts.
Bump to add that as well as the smaller high KV motors, I’m also currently interested in BN Split Angle or other precision Caliber II compatible baseplates to use with BN270 hangers. I have some BN Adjustable Baseplates but they’re too tall for the current setup so right now I’m using some regular/stock Caliber II baseplates which I’d like to swap out of since they’re cast and will prob crack at some point.
Last I heard BN still had some of those. Have you checked?
I haven’t asked BN directly yet, could be worth a shot - the website says avail on Backorder which I figured was prob equal to not avail with BN winding down. Right now I’m pretty dedicated to reusing/refurbing used parts for my builds if possible for cost saving as well.
I think some of the last parts they had in stock were the split-angle baseplates, try sending Kevin a DM.
I would leave well enough alone… lol.
Ha - I have had cast baseplates crack but like most of my parts they were used so history unknown - same with the ones currently on there tho. So in the meantime I did order a new but still cast 50/35 set of baseplates from sk8kings - and sprang for the hardcore aircraft grade kingpins.
Also I did ask BN/Kevin and split angle baseplate stock is gone.
Bumping before I buy new - seems like the type of thing people don’t often sell off but looking for at least 2 not-XL Rockstar Pro II Aluminum Hubs to complete a half set I have but also XL hubs too since they’re always useful
I got a set of pro 2 xl hubs. I’ll message you
