Looking for some of those deck inserts for the lacroix nazare or supersport decks.
I was missing 2 inserts from a used deck i bought. I ended up buying these Amazon.com that were the same size as mine but a bit taller. I put a Hex bit in the drill and spun the insert on some Sand paper to get it to the right height ( 10 seconds of spinning) and then they fit perfectly with a little epoxy to fill some space
Might go that route if I can’t find the correct ones.
Too tall
