I definitely ran across this thought last night.and I ran across the picture you posted.
But there are no Hummie decks for sale…
Bugger. John is sooo slack.
just measured, it’s 49mm between the bottom of the enclosure and the ground,
this set up is super carvy, on full lean I can get a finger between the enclosure and ground (about 12mm)
Looks like the Paris and Bear Grizzly would give the most height
So things I have also pondered is getting the eboosted enclosure for the Demonseed.
But it is probably not as low profile as the bustin.
Or another Enclosure that is not as wide…
And getting Boardnamics adjustable baseplates to add height.
I have one showing up Tuesday for another board i can try out.
The Demonseed one doesn’t appear to be much deeper, i like the idea of adjustable base plates so you could get just enough clearance and keep it low
I keep refreshing Unlimited X webpage but no Memorial Day sales…
Considering these myself
those looks magnificent!
So yeah dude.
@iespobolamas
The adjustable baseplate adds 16mm.of height…
That is a ton…
Should make this totally doable…
Still a bunch of money… If I go down this rabbit hole…
I am now thinking of spending that on a onewheel pint…
Nice!
get in that rabbit hole
what angle does that set the trucks at with that height?
and looks like the locating pin on the side of the baseplate will get in the way if you top mount, guess you could cut out a bit of wood, or maybe use a flush pin instead of the bolt, it won’t be coming out once the truck is mounted
or sell the Boardnamics mounts to fund an Eboosted enclosure for the Sportster you have?
than you’ll get more of the low low feels
I really like the sportster analog.
i don’t really go on serious analog trips. just dork around in front of the house.
but still, it feels perfect to push.
i had it at the 50 degree setting. looks like 40 would add similar height…
stupid me, i did not actually drop the baseplate on teh demonseed to double check, but i am pretty sure it can be mounted drop though without issues.
i will go check now…
It can mount dropped through fine on the Demonseed. As the slot has an opening in the middle.
The straight slot on the Bustin would be a no go…
perfect!
yeh the Bustin is limited with that slot, can’t even fit in Bear Grizzly as it has the side dimples on the baseplates
i’m justifying this with profit made from wheeling and dealing Lego
Awesome.
I bet that thane is going to feel way better.
Ultra jelly
