I’m looking for a battery around 1kWh in capacity that can fit underneath a longboard, approximate measurements two 18650 cells high (36mm) by two cells wide (130mm), length can vary based on total pack capacity. It should have a smart BMS and not need an external BMS for charging. Ideally 13s 48v, but lower is fine. It’s even better if you have a hard shell case as well.
Price target is around $300 shipped. Located in Texas, USA…
$300 /(1000 Watt hours / 10Watts hours per cell) leaves about $3.3 per cell… What’s cheaper than any cell I know of and does nothing for actual labor which is substantial.
1000 watt hours is about a 90cell battery. Or about a 6-7 p battery. Not sure what the going rate is. But I’m guessing something like double the offer here.
Are you planning on using this pack in any environment where it’s subjected to heavy vibrations (like a longboard) or store it inside a home while not in use?
For one, they aren’t actually anywhere close to 1kwh. I had one that only delivered about 300wh on a friend’s bike. Secondly, those batteries can only output like 20 amps, and are huge.
