[WTB] [US] 270mm 12mm width belts (enertion mounts)
Hey everyone, I recently sold a pair of enertion style mounts and the guy needs some belts. I tried some 9mm 265mm belts and they were a bit short and definitely too thin.
I think 270mm belts would work best.
15t motor pulley, 36t wheel pulley
I have tried to find some with no luck. I could only find 15mm. I don’t think 15mm will properly fit
#Aliexpress € 14,71 7%OFF | 10 pieces HTD270-5M timing belt Teeth 54 Length 270mm Width 12mm 5M rubber closed-loop belt 270 HTD5M S5M Belt Pulley
https://a.aliexpress.com/_d6VTMFf
For if you cannot get them quick.
Duckgo the phrase “270-5M-12 synchronous timing belt”
Buy from Aliexpress for cheap
Buy from VBeltGuys or eBay or Amazon or VBeltSupply for fast
Buy from Gates for good (arguably)
https://www.vbeltsupply.com/270-5m-12-1.html
https://www.amazon.com/dp/B07MWDR7FS?tag=duckduckgo-d-20&linkCode=osi&th=1
