Hey i need a new 12s charger. anything 5-10 amps and GX16-3 Should work
I’ve got a cheapo 2A charger if you’re really in a pinch.
GX16?
I have a 12s 15a I can sell you for $100 plus shipping. It has a xt90 output.
Make sure you check polarity with a multimeter. there’s no standard for these connectors since they arent meant to be used like this.
Thanks for the heads up
Think ill pass for now since im gonna be getting a variable charger next. Thanks though!
which did you get?
meanwell seem the best: cheap, small, no fan, waterproof.
im either gonna get the Chi Battery one because of the adjustable percentage to stop at or this one off of ali express https://a.aliexpress.com/_mPJmcdk
I don’t know those in particular but I’ve broken a ton that look similar. The fans often break first.
I can’t find a good meanwell option but I’d call mouser and tell them what you’re looking for and bet there’s one the same price and ability but much more robust
this model in the pic is great but get the voltage range you want. It’s adjustable n silent and will last
Called Mouser and they didnt have a 50.4v
what i linked looks to fit the bill
48v instead of 50.4v and id like the adjustable amlerage to be a little higher. Thanks for looking tho i appreciate it!
its adjustable. I added the data sheet in my last link. the voltage is adjustable. the current is adjustable too but maximum will only allow 320 watts though so not that much.
If you want something higher power I’d look for another meanwell
What’s that one adjustable charger you guys use? @MichaelWA @Egtscs
It’s variable and they got it for super cheap on Ali. A bit bulky tho
I also got my 12s12a charger from Ali for $70. It’s the same model as Radium/SKP sell, but it’s not variable
SKP sells 12S chargers. One I got from him is 6A, not sure what they are now. You could ask him to put your specific connector on it.
The SKP One isnt adjustable so thats a deal breaker for me. i was looking at it though!
