Looking for a 10mm bore motor pulley w keyway slots.
I got 15t no keyway tho… I just screw the set screws into the keyway groove
Metal or aluminum?
Edit:
Steel or aluminum
Aluminium is metal
I think you meant Steel.
Aluminum
I do the same thing + a dot of loctite 603
Never failed
hey I should actually have a few 10mm pulleys with keyway. I can look for them tomorrow
Awesome. Thank you.
Is it 1 your looking for?
@pookybear
@pookybear still looking for one? I found a 14t and a 16… the 14 is missing a flange. should not matter if your drivetrain is straight. you can jb weld a washer to it if necessary.
the 16t has 2 dents in one of the flangs. can be straighten with a plier. missing grubscrews on both…(m3)
I´ve been pm´d by others who´s looking for 10mm bors with keyways, but you are first in line so let me know
Yes please. PM incoming
Close please. @BillGordon
Traded my 8mm bore pulley for 10mm ones from @Skyart
