WTB: Speedict Neptune 15/20s BMS new or used.
Looking to buy a spare Neptune BMS if someone has one.
what’s wrong with using an LLT or Daly?
Nothing wrong, do you have a suggestion for a low footprint BMS that supports bluetooth and in reasonable price range ?
I have a new 20s LLT BMS still in box, if you want to buy it. $35+s&h
I think it is very large no ?
The latest generation of LLT are all quite small. Daly is very big though
Bigger then a Neptune, but not that big
I see that many BMSs have a low discharge rates such as 30A , 20A etc … (the more compact ones at least).
Does this matter ? I mean isn’t that restrictive ?
Or that most people are just giving up and installing their BMS as charge only BMS ?
What do you people think ?
Here is just one of many topics on the matter. Search for “discharge bms” if you want more horror stories.
The vast majority of people here run charge-only.
charge only is safer, having brakes n’ all
*and program the low-voltage cutoff in vesc.
It doesn’t protect against an abnormally low cell, but if you don’t drain the pack voltage down to like <3v/cell it’s fine.
Does bypassing affects anything to do with cell balancing ?
Say BMSes that are doing leakage of current to balance groups, do they get affected by this in any way ?
Bypassing discharge through the bms shouldn’t affect the balancing function in any way
your BMS primarily balances while charging anyway, as long as your esc can turn off there’s zero downside to bypass.
Maybe except over discharge … ?
your esc or vesc should have a minimum voltage cut-off to prevent that, and as I said as long as you can turn the esc off the pack won’t discharge outside of actual usage.
a loopkey is the ultimate shut-off, completely preventing discharge.
