I am looking for esc or esc+whole case, but it has to be in working order. I know it’s a long shot, but still hoping someone has some leftovers
this one:
this one:
seems like a good time to upgrade for a vesc? depends on depth, makerx has good options, either the dv6pro or d60 or m100
yes, that will be second option if I won’t manage to find original esc.
Most people here would encourage the VESC option.
That is a hobby wing esc right?
Doesn’t look like a Ling Yi and hobbywing is the other common esc out there
Also if you go with a VESC you will likely need to make your own case or try and use the case from that one.
Slick revolution has propriatary escs as far as i know.
that would be my guess too.
It’s friends board and he would like to fix it for as cheap as possible. I was hoping to get original esc for like 50-100$, and if I go with makerX DV4 + anti spark switch + remote + taxes it will cost 300$ or so. and friend will probably never upgrade anything else on board (stock battery is 7 or 8s, motors are pretty small, probably 5045 or something like that) so even DV4 won’t ever be near its max potential.
The esk8 sub reddit buy/sell thread is usually the best place to look for replacement parts for production boards. Might want to post over there too and see if anyone has one.
Hi Tin,
Luka ovdje iz Zagreba. Ne znam kak ti poslati poruku, al trebam pomoc oko baterije. Imas li insta ili mail?
Tin, Luka iz Zga. Treba mi pomoc oko elektricnog skejta. Imas insta ili mail?
This is an English speaking forum. Please only use English language here, thank you.
unfortunately, no. didn’t find replacement.
I let’s you know if I find a solution, it’s look like aerial, ESV or BMS is broken.
Any one out there that might know slick revolution esc receiver pin out? I was able to buy a 2nd hand S/R battery and it’s came with the esc but had no remote. It still had the receiver which is a pity. But does anyone know the pin out on the receiver? I was thinking using a R/C receiver but one the has a small hand remote. I’m sure it’s works with the same vcc, 5v, 3v tx, Rx, ground ECS. So was wondering if anyone knows if this may work?
