As says in description looking for some htd5m 420mm long 15mm wide rubber timing belts
In uk/Eu please pm if you have any
Thank you
Thank you
Are you sure you’re not looking for some tennis balls?
There are three places that I know of that have readily available belts most of the time in all sorts of sizes for 15mm width.
@EboardSolutions is the one that has them right now.
https://www.beltingonline.com/5mm-htd-timing-belts-4575?zenid=c8atck225nsi4akl8auv4uscg1
~2 day delivery in the UK, any width/size you need.
£16 overall which seems a bit steep for 2 belts
Not when they outlive 3 sets of shit belts
There’s always more to it than face value.
$10 per belt give or take $2 seems about right to me and that what I pay for 275-300mm belts.
Fair enough was just thinking that someone here must have bought some belts which they ended up not needing and want to get rid of for cheap
I probably have some to be honest Shua but the idea of digging them out and posting them to someone offends me at a base level
I highly recommend those contitech belts from beltingonline or rscomponents.
Well thanks a lot…
Nah it’s fine just hoping that I could get some for a bit cheaper as I am pretty broke currently and £16 is quite a bit for me
Bought 4 belts got my mum to pay because she says been a massive help by babysitting my little bros the last couple of days
I swear if I got the wrong size though…
Also @Brenternet gonna be in Bournemouth just after Christmas will make sure to look out fo thou there
£ 6.67 a belt at that size.
£2.50 delivery last time I used them.
use them because of the big choice of with to fill the pullys.
Just received this from beltingonline
Please if anyone can then tell me if you have a spare belt or two as I am really desperate to be riding this thing over the holidays
@Brenternet your my last hope
If possible would you be able to find a belt or two
Thanks so much if you can
Unfortunately that’s not the case. I am in the middle of a house move and those belts are buried deep. That’s what I meant above.
You’re on your own here bud.
K thanks for the help though
The jokes old by now
Keep trying…
