I got kne with a broke antispark and shorted pins tl use with a loupkey. Not to bogart @KaramQ but @monsterbuilder this seems better than what i had to offer you lol well not better just cheaper
Can you tell me more?
If I have one Unity running normally with on/off switch, then this one youâre selling driven by canbus.
I would just add the Loop Key that I could pull/insert to use as the on/off for the 2nd Unity?
My unity is perfectly fineđ, and Iâm asking $220 shipped, buy so I donât end up making another build. No shade to Steph but when you short anything on a pcb, it most likely means something else will come up later on. $220.00 for a OG unity is a killer deal and you wonât encounter the newer unity QC problems
Switching the low side while you have CANBUS or any other low voltage ports connected will essentially put high voltage on those ports. And I donât think Iâd want to put -51V on a CANBUS wire, might not end well. But I havenât tried it.
As long as you switch the red it should be fine, although just spinning the wheels will be enough to boot up the second ESC, and that will probably make this not work in 2WD mode. But at least not work in such a way where as youâre not destroying something.
