Anyone have evolve trucks? I am looking for gen 3 in particular.
Thanks.
Need them ASAP.
Evolve is out and so I am kinda in a holding pattern. Please save me.
Doug
Thanks.
Need them ASAP.
Doug
Rear or front? Aka with motor mount points or without?
Hey Brian,
Doesn’t matter actually. I’ll which ever is in less demand for you. How much are you asking?
Thanks,
Doug
Pretty sure you need REAR if you are mounting it. Just FYI.
Yeah, I actually have the rear mounting strut already and got yourmotor mounts. Just really need the hanger, base plate, and bushings. So I’m willing to buy anything at this point.
I have a set of tb218 trucks and 3ds gear drive if you need? Also a set of surfrodz rkp. I am close to you in Irvine.
Hmmm. How much? Can I mount 6374 motors on it?
Yes. that would be good. 250 for everything tb218 and gear drive. You’d need to cut down motor shaft depends what you have.
Sorry. Way out of my budget.
Hoping to get a used really shitty truck.
Should have gone boardnamics then got gear drives later…
More common than evolve at this time and greater resale value.
Hi! Are you talking about the rear strut (see photo)? I have an extra duel drive and a single drive if that’s the case.
Sorry. I have plenty of those.
This is going to be a test mule for years for all the other wheels I am making
Seems like its in stock?
And the silver arm is cheaper:
Oh, I was not aware the Gen 3 bolts up to Gen 2? I have the gen 3 truck, but nothing else. So is this to say that the Truck Arm Gen 2 matches up to the Gen 3 strut?
It is a test mule that I want to use for a lot of marketing videos and development of the 125 to 130mm Hollow Wheel. So I don’t plan to sell it for probably another year or longer. As such resale value isn’t so important.
Right I was thinking it was a much shorter term use but I see your points.
Would not want to tie up money in expensive parts
Never tested it myself, but looks like these might work from backfire for $25 USD.
Description in this video mentions the shalf size along with a # to call too:
Ships from USA I believe. Would they work?
Yea they are both the same. I have the silver one mounted on a newer baseplate. only difference is the black color.
Yeah, that looks good. I am just not sure if there are mounts that would allow me to fit a 6374 motor.
