WTB EU MTB Trucks + GD + Wheels
Hi, I would like to consider some offers for a set of MTB trucks with gear drives, suitable for Flux deck.
Now I have stock trucks with MOON gear drives, but the version is very old.
So I would like something better.
Thank you.
I have a set of matrix 3 trucks equipped with 3ds gear drives and skp 173kv motors. They are equipped with adapters for MBS rockstar pro 2 aluminum wheels.
Ah I just noticed you’re in EU. I’m in the US
Still very looking, should I buy the BN trucks and rims since the price is very good? Anything else to consider at that price range? Been out of the for too long..
At that price range, hard to find anything better. You can also check the idea trucks if they are available . Then there are dualities and rev trucks but they are expensive
If you want some BN channels I have pair in the EU I am not using. You’d need to buy replacement kingpin bushings from igus but that should be cheap. Let me think of a price. Might also have a matrix ii drivetrain that i dont need with bn at gear drives which also have some caveats, let me check
Igus is very generous with free samples :wink:
Happily waiting
I’ll open up the gear drives today, take some pictures, and figure out the price.
Two possible options:
BN 310 channels and I also have good condition BN AT drives to go with them with the correct adapter.
Matrix II channels with BN AT drives that have some quirks but work well (will send pictures whats up) and FS6384 BH motors mounted, sensors are dead in at least one, maybe both. Probably quite rusty on the inside but they do work and bearings are okay (relatively to flipsky, they have the usual flipsky whine). Can sell this drivetrain with or without motors. Drives and trucks are inseparable.
Would be shipping from Denmark.
I finally got around to opening up the drives. The matrix ii setup needs some work that I don’t have the time for right now so that’s off the table for now.
So heres the BN310 channel setup
There’s some minor cosmetic stuff but everything is relatively good condition, functionally perfect. The only thing is that you need new igus kingpin bushings for the rear truck, as the current set has some play.
Your choice of 3.8 or 5.2 ratio, I have pinions for both but would only sell one pair of pinions.
One truck has a 5 degree baseplate, the other is 0 degree. I also have a pair of green bushings I’ll include. White is 70A, red is 75A, green is 80A. I think I was running white front/ green rear when I had this setup for higher speeds.
The gear drives are unobtainium (like all good gear drives…) and one of the most reliable drives that used to be on the market. They were 300$ new plus shipping and import, trucks are on clearance now for 160$ new plus shipping and import. I think 225€ for the drives and 125€ for the trucks sounds fair given that they are in good condition. Shipping is probably 20€ or so.
