I’m currently running my esk8 with the TB single motor kit V6 and I’d like to upgrade to a dual motor system. I’m thinking about buying 2x 6354s and sell the Flipsky 6374 (they should fit in that truck right?).
My current setup:
Trucks: TB 180mm
Wheels: 83mm ABEC
Pulley Ratio: 16-36
Belt: HTD5 12mm
well on standard caliber trucks and 12mm belts, TB 6355 motors and mounts work. (I used to have that setup) Flipsky 6355 are just as large, so theoretically if the mounts are just as thin, and you use 12mm belts and bolt-on pulleys – yes
