WTB 350mm belts and 16tooth pulley(s)
Hey guys I’m looking for a couple 5m-350-12mm belts and also a 16tooth pulley or 2 to go along with them if anyone has anything. My belt shredded today on my commuter and I can’t find anyone with 350s.
What mechanical setup are you running? You might be able to have a range of ± 5mm which makes it easier to find?
16 - 60 with 6 shooters and Psychotiller mounts.
Do you have measurements for the center to center range?
Some versions are 60mm ± 2mm but that gives a 330mm belt as the only viable one which is clearly wrong
I will have to pull a wheel off to get a good measurement, I have a 330mm and it’s not even close.
