Bought these trucks a long time ago and have kinda been stuck with them. The honeycomb wheels dont work with them so im hoping to get some ideas on what will work. I cant use urethane wheels as the roads around my area are bad abd the sidewalks are equally worse
It looks like the bearings that come with those wheels are designed to work with 12mm axles. So no, they won’t work together without some modifications.
Your other challenge with that style of truck is the potential for wheel bite. What deck are you planning to use?
I use torqueboards v2 deck. I run 15 inch trucks already and they hardly come close when turning. And i know flipdky loves their 12mm diameter axles so already planned on switching the bearings
I dont see where you guys are getting that those wheels take a 12mm bearing. They seem to take standard 608 bearings and therefore should be perfectly compatible.
