I think the google-foo is not so much of a problem than just a general lack of electrical knowledge
I didn’t know about the NO and NC meanings, I thought the label said ON…
Do I get this straight:
Antispark GND to button NEGATIVE
Antispark +12V to button POSITIVE
Antispark SW+ to button NO (if I want the board to be on when button is pressed down)
Antispark SW- to button C
Forget the fact that a switch has a postive and negative terminal. Thats just… wrong.
No matter how you terminate it the function will remain the same. In this case SW+ and SW- is completely irrelevant. You can put a wire between those two pins and it will act as a button in the on position.
If you want to verify which pin does which, I sudgest you probe the button with a multimeter, meassuring Resistance f.e when it goes to 0 it means the button is conducting. Best way to be sure your connection is like you want it. Also.If you’re planing on soldering onto the button tabs you need to be super quick about it. Cause that button will melt.
You can try to just tap the + and - of the LED terminals to see if lights up like it should or if it goes poof. Or you could just check with the source of the button if it can take 12V.
But yes. Connect the “C” to either of the SW+/SW-. and choose if you want NO/NC function.
