I have a turnigy sk3 with a 15t gear and a flipsky mini. running 7 inch evolve AT wheels.
The VESC hits 85-90 within a few kms if running hard at around 25amps from battery.
Where can i get a compatible gear that is 13t. with grub screw and 8mm bore.
Im in australia. i dont mind buying online.
I only know you can get one from trampa. https://www.trampaboards.com/custom-choice-motor-pulley-aluminium-or-black-steel--supplied-with-mgss-grub-screw--keyway--13-14-15-tooth-p-13931.html
You can probably find some on aliexpress though after a bit of searching.
I found probably ONE article on Aliexpress and they had 3 pieces of steel 13t pulleys for d shape 8mm (which I’ll rework to make it fit for the normal 8mm bore) and I’m not sure if it has grub screws. I’ll post the link anyway and try ur luck
€ 8,85 | 13 16 19 Tooth 13T 16T 19T 3M 5M D Type 8MM 10MM Belt Drive Razor EVO X-Treme IZIP 250W 360W 500W 800W 1000W Electric Scooter
It’s written only 1 left for the 13t but text them and ask if they have any more
