Can anyone point me in the direction of where I can order some 12mm axle lock nuts from for my hypertruck lites. I’m located in the US. Thanks in advance
i get most of my hardware from fastenal. from nuts to bolts
radium also offers these if you want some nice looking ones
https://radium-performance.com/products/titanium-wheel-nut-for-matrix-2-for-electric-skateboards-longboards-eskate-esk8-diy
I have those… they are good but you need to use a 19mm socket.
why can’t you buy a 19mm socket or an adjustable wrench? (just curious)
Wasnt aware. Thought the smaller (standard) size nuts used a different socket size. Ive only ever had these from radium
I’d recommend boltdepot.com over fastenal
For standard 12mm hex lock nuts, OD should be 16mm
I just found the one missing locknut i needed in the glove box of my car woohoo! Thanks for all the replies, now if i ever need some i know where to go. Initially when i couldn’t find mine i almost bought those from radium they look nice
lowest i’ve seen is 18 flat to flat
Huh, idk then. The 12mm axles I run on my Dualities use a 16mm hex wrench, but those trucks are my only experience on 12mm axles, so maybe it’s different on other trucks
Although only Green appears to be in stock.
