My VESC based setup is finally ok but I notice my wheels are not starting at the same time when I slightly push the throttle
I don’t like it because one motor is forcing more than the other and I suspect it will be problematic on the long run
Can I / How do I fix that in the VESC Tool?
Can you actually feel this when riding the board? Usually 1 belt might be tighter or you could have a bad bearing, so one motor has more resistance, but under load this difference is unnoticeable.
It also helps if you can go from -104% pushing the trigger forward, to 0% when you are not pushing or pulling, to +104% when you pull the trigger all the way in.
The extra 4% means if you apply full brake or full throttle, you don’t have to keep the control mashed into the very end of the range for it to stay at full power/brake.
