I think design a prototype patent that shit and sell it right back to the company that is producing them.
how about I cut slices of old bushings I donāt want then attach those
casting my own thin strips to wrap across would hold up better though I think, using a printed mould and tough material.
@RipTideSports would you be able to advise me on how to attach urethane to urethane? their surface is slightly textured.
What about neoprene gasket strips
haha sorry gotta laugh you really think you could drive on those? I need something that will not fall off and pollute
hence tough urethane in large pieces covered in adhesive being best I think.
oh Polyurethane glue and flexible epoxy right
Other options I considered besides attaching stuff by glue is wrapping rope around before inflating and that would give a rougher surface. The wheel hub I make could have holes through it for the rope to pass.
Youād have to have ultra tough glue. I imagine the rigidity of the bushings would cause them to tear off. I thought neoprene or rubber because it would flex w the wheel as you drive over hard surfaces. The bushings would force the wheel to flex around them I would think.
The master is typing.
Roughen both surfaces and clean with acetone then use a moisture activated urethane glue like Gorilla glue
I said cut slices it sounds like you think whole bushingsā¦ I donāt have that many.
they would be pretty small but they might still come off and a wrapped material could be better.
Maybe I should try wrapping it with stuff first then the glue.
I was thinking if I cross wrap it tightly then inflate the wheel would have a lumpy surface instead of smooth but I bet it works fine and it would impede it working properly on soft sand.
there seems to be plenty of traction due to the low pressure.
I bet I could use strips of rubber from bike tires wrapped around
We have defects but no real production scraps like a wheel maker would have
like I said if I really wanted thane to glue on I would rather cast my own long strips.
Can you melt them back and reform them? (I have no idea of the chemistry of urethane.)
would assume it modifies the properties
Comes with treads
You canāt melt thermoset polyurethane and reform it like that. Itās closer to epoxy in that regard.
I bet I could get a kids bike tire the right size and just get it stretched right over the middle no cutting strips and wrapping.
interesting how you can repair these wheels punctures and rips with a soldering iron, I am actually really excited to try out a roadside tire repair with a ts80
suppose it is just like melting and burning not being reformed or something idk.
Would you ever attempt a inflatable PU wheel? I know you were working on some secret tech that was something quite different.
I am thinking about trying it to see what kind of failures it has
wanted to ask @CHAINMAILLEKID about it
wrong tag sorry
Circling back to this. The tire itās self is 24 x 12.3 cm (9.4ā³ x 4.8ā³) thereās gotta be 9.5x5 tires.
