I could see hubs for these using almost a full roll, so probably like $25 haha
tbh I think the non-bearing parts of this hub could be printed less infill. I can take a crack at making it in multiple parts so some can be weaker maybe… I would want like a metal part joining them together somehow then. idk needs more work to be a more efficient solution there.
The hub could be two parts I guess one with the bearings and the other with a rim.
One could probably make a dually hub with metal for a core structure.
or just run 30 cm in the back and 23cm in the front.
@b264 see here,
the top bit would be the right part here, and it could still be printed full infill but it should have less material in the middle.
like so.
All the bearing seats could be flipped and make the bearings captive if I slice it into parts like the first pic. Not sure how I feel about that.
with this .5" double drop at full lean you should still have quite some clearance.
idk turn circle is looking pretty crap. I think a different kind of truck would work a lot better.
I keep thinking the 1st eSK8 on the moon is going to look like this, talk will be about what gas to fill them with to get best airs on crater rims lol
as long as it’s not a scooter…
You need DKP I think since this won’t be going fast anyways
I have those where is the evolve trucks model?
I only have the dimensions of the mount plate to axle
Maybe consider a waterborne surf adapter and extension
I got the extensions, did not have the cash for the full surf adapter.
Can try the DKP first.
Leaning truck baja style would be ideal
Fixed a dumb hanger clearance mistake on the pulley spacer and made it wider due to wheel wrinkle imperfections interfering.
just barely too tight for 6374 with the new pulley clearance.
Look they survived on a FRC robot:
https://drive.google.com/file/d/0By2bYoKVZHVTem5BUGNzYU9OSGM/view
well I mean, and all those Rovers in the university challenge.
I just couldn’t build a battle bot without trying to stand on it, I would get kicked out of the team early on for insisting there was a for feet
thinking about it I suspect my bajaboard just going backward and forwards in that area could have destroyed them, all
