whats the best strongest cheapest m mounts?
He does sell adjustable crossbars now
I take it as you already have tb218’s you are no longer interested in mine?
I make my own from M4 treaded rod a few nylon loc nuts and a blue anodised stainless drinking straw.
Is there some problem with using the idler? Curious why you recommend going without it.
Adds more things that can fail, wears out belt from both sides instead of just one side, isn’t really needed if you set up and align the belt correctly.
I use to think like that but then I tried them. Loose belts that don’t slip is like magic. They are not for everyone it is another part that needs servicing even if you don’t use the idlers, the idler mounts are longer does makes reversing them simpler.
