What setting for bms?
At what voltage you set it to start balancing and how much variation permitted?
Guessing you want to balance during charge? (most common)
Typically start balancing (if needed) above 4V.
allowable mismatch before balancing somewhere in the neighbourhood of 50mV.
Depends abit on avaible balancing current and your packs capacity I’d say.
Yea during charge.
50mv being .05 volts I believe. Sounds good thanks.
This depends on chemistry as well — these numbers are not for LiFePO4.
