Iam working on steel gears my friend, for etoxx mini 40/9 straight. THANKS FINALLY SOMEONE who is thinking the same. Production for beta starts beginn of march :). Also I think the sound will be like a race car gearbox. Njjejejennneneg
Slime
RC Car gearsā¦
in the 1/3 scale?
I think we needā¦
Continue to improve failsafes in the ESC. Ideally, a way to maintain brakes and default to free roll when thereās any system failure. Same from the BMS side. Bluetooth connectivity, app.
Trucksā we need esk8 designed trucks and suspension from major manufacturers. Designed for the abuse esk8 takes compared to long boarding. Hanger mounting options for lights. 10mm axles, potentially Mount integration.
Urethane gear drives! Urethane needs the motor clearance to improve by getting motor as close to hanger as possible. Front or rear.
Direct drives, depart from 8mm axles please.
From the community?
Fusion 360 esk8 related CAD tips and tricks. Enclosure design etc. Multi-user input could help find ideal esk8 part compatibility for multiple setups. Would help our member vendors and members.
lots of new users with 3D printers.
YES GOD PLEASE. I donāt understand this POM shiz
Are there lights where you can bolt directly onto something. No clamping mechanism or straps
Like a panel mount bike light
We need to stop depending on one country for most of our core esk8 parts, and batch produce cheaply and efficiently reliable quality parts - talking batteries, motors, escs, bms, remotes.
Remotes!
I need it to be waterproof, have it to be able to control lights and I need break lights and turning lights on my board
good one. You want it cheap AND not from that country? Get back to me when you figure that one out.
Yeah this default, immediate, warningless, and unsafe ācut brakesā when there is an ABS_OVERCURRENT exception is complete unadulterated bullshit
It should ramp the brake power down and if the error subsides then leave it there (similar to an overtemp situation) or if they need to be turned all the way off, fucking have a motherfucking ramp-down of some sort.
Iāve eaten shit very badly because of that before
Within reasonable rangeā¦ i see decks pressed and finished in the US that are of great quality and sold at reasonable price.
I am a bogan myself I want more noise i would do burnouts constantly if it did destroy my battery capacity.
My wishlist for 2020
Solid gear drive.
Speedboard diy kits
A remote that uses canbus with bms integration
4200mah 18650 with 20A constant
A Quad 6.6 vesc
The Raptor III (just joking)
Tooless wheel changing
More ajustable angle truck options
Maytech split trigger V2 does all of these things and I love the V1. Some people have had issues with connectivity in big cities but I imagine youāll be fine where you are
